My current patrol is a 2004 4.2 Turbo Diesel Intercooled Patrol ute.
In the 1st week i fitted, twin ARB air lockers, dual batteries, Warn 9500XP winch, ARB bar, side steps, Lightforce XGT lights, UHF radio, arb head and spotlight looms ,65L water tank etc etc.
over here in Oz the Ute comes with 190L fuel tanks from the factory.
i still have to fit the hot shower kit
GME 3400 TX remote
locker switches in console
air manifold under the bonnet, air in from compressor, quick connect, locker solenoid, pressure switch, locker solenoid, and air out to tank
second battery
dual batt solenoid
the gap where the header tank bracket should fit but doesnt on new GU 4.2TDi utes
arb headlight and spotlight loom relays
air manifold again
LIGHTFORCE XGTs
Warn 9500XP 6hp
ARB compressor in the cab
Dash again
Hi Roly,
welcome here !!!! Nice Troll you have !!!!!!!!!!!!! :2 (24): Just a question : what means "ute"....? :2 (21):
I guess that u like "ARB" :2 (26): ! Me too.
I "edit" your post to write the price of fitting in EUROS... :2 (20):
ute is short for utility, which is an aussie invention in the 1930s
dont let the yanks tell you they invented the "pickup" first :2 (10):
:action-smiley-030: Hello Roly
:enaccord8: You have pretty a 4x4 which is not current to cross by on our premises. :2 (15):
fitted the hot shower kit from twine
heat exchanger mounted to Intercooler brackets
water in and out connections
shurflo pressure pump mounting
shuflo mounting and hot water pipe running around firewall to exchanger
we use a heater tap under the bonnet so you can control the water temp from the shower rather than the standard install which means you have to use the heater controls in the car itself....
exchanger exit pipes, not mcuh room on the new TDi
heater tap plumbing, no cutting of factory hoses was necessary, so by undoing to hose clamps the entire shower system can be bypassed and returned to factory in the event of a problem
Hi Roly, welcome !
Very nice Patrol ... but engine compartment now looks like a powerplant ! :2 (15):
Hello Rolly , Wellcome here :2 (19): it's a very beautiful TROLL :2 (20): but stop it immédiatly , I'll be MAD :2 (24)::2 (24): ,I WANT THE SAME :2 (22)::2 (22)::2 (22): Please Santa Cl**** I want the same for CHRISMAS :2 (21)::2 (21):
Nice job Roly !!! :2 (24)::2 (24)::2 (24): Have u done it yourself or by a specialist ? Nice to catch u here again.... :2 (14):
  • 1 an plus tard...
et nous dans ce pays de misere on a que des moteur en bois.......... :panneau[1]:
I'm afraid that we couldn' find this model in europe. :2 (22)::2 (22):
it may interest almost workers in town and country... :2 (13):
we will be enjoy if you have anothers pics of your trol :2 (26)::2 (26):
what is the models of yours tires :2 (18):
il es vrais que ce model n es pas commercialisé ici en france mais il es possible d en avoir un... :corse:
en avoir un........comment , Steffi ?
as tu un filon ?
let us know !!!!!!!!!!
il est vraiment super son Troll :2 (26):
