SUITE A STOCKAGE DU PATROL Y61 2.8 PENDANT 6MOIS IL NE DEMARRE PLUS . J ARRIVE A LE DEMARRER AVEC START PILOTE MAIS IL FUME GRIS ET A DU MAL A PRENDRE DES TOURS.NE TIENT PAS LE RALENTI , SAUF A CHAUD
J AI DONC ENLEVE LA DURITE A L ENTREE DU COLLECTEUR D ADMISSION , PAREIL. J AI MIS UNE POIRE APRES LE FILTRE GO ,LE GO SORT BIEN. J AI DEPOSE LA VANNE EGR ET LE TUBE ENTREE DE TURBO POUR VOIR S IL N ETAIT PAS GRIPPE RAS. PEUT ETRE CALAGE DISTRIB OU PB POMPE INJECTION .
SI QUELQU UN A DEJA EU CE GENRE DE PROBLEME . MERCI D AVANCE
JE PRECISE QU AVANT LE STOCKAGE IL M AVAIS FAIT UN COUP DE PLUS DE PUISSANCE ET REVENU A LA NORMALE APRES REDEMARRAGE IL ETAIT DEJA RESTE UN MOMENT SANS ROULER
BONJOUR A TOUS.
