Posté(e) : 25 mai 201213 a How can you give a Patrol GR Y60 some more power? I allready played with the pression of the turbo ( 1 bar ) and with the fuel pump a little. But the fuel pump is not that effective so I want to know what you can do to give the beast some more power?
Posté(e) : 25 mai 201213 a Have you installed intercooler on you vehicule? You said you "play" with fuel pump, but did you use tools to do it or did you ajust it with your mind ? Because change fuel setting could decress power if adjustment is not perfect
Posté(e) : 25 mai 201213 a Auteur Have you installed intercooler on you vehicule? You said you "play" with fuel pump, but did you use tools to do it or did you ajust it with your mind ? Because change fuel setting could decress power if adjustment is not perfect No I don't have a intercooler, I want one from a REnault Espace 1.9 tdi because it's pretty large. I didn't used any special tools, I feel it's getting some more fuel but it's a waste. It helps a little bit but I want to change my fuel pump on the inside the plungers and the injectors and another camshaft but it's pretty expensive.
